Rear brake squeeling
Old Dec 19, 2006 | 11:48 AM
jv1's Avatar
jv1
jv1 is an unknown quantity at this point
Default Rear brake squeeling
OK, I have replaced the rotors and pads on both sides in the rear. Onecaliper slide was siezed up so i cleaned it all up and got it moveing freely again. That wasn't the problem. Everything was lubed up and cleaned up but still the squealing.The pads do fit in VERY tight . Is it possible that they are not sliding good and causing the noise?
Old Dec 19, 2006 | 12:01 PM
Default RE: Rear brake squeeling
When I did the rear brakes on my Bravada, I had to push the little metal clip on top of pads in the caliper up some with a screwdriver to keep it from rubbing on the outer edge of the rotor. This was the cause of my squeal after that repair. Drove me nuts.
Old Dec 19, 2006 | 12:06 PM
jv1's Avatar
jv1
OK i didn't notice that but will definately check it out. Are you talking about a clip on the pad itself or the clips that hold the pads in?
Old Dec 19, 2006 | 12:46 PM
Let me see if I can find an illustration...
There ya go. Courtesy of PartsAmerica.com - Raybestos Quietstop Ceramic Pads
The parts I'm talking about were the clips that the pads slide into they are the ones in the lower left and right corners of the picture. For some reason the section that crosses over the rotor was tipped towards the rotor and rubbing the outer edge.
Helter80
Sep 13, 2013 10:55 AM
sndro666
Dec 18, 2007 07:22 PM
hockeykid15
Jun 19, 2007 02:52 PM
96Ls4Dr
17
Apr 9, 2007 10:10 AM
Don
Jan 16, 2007 11:22 AM
