Rear Defrost
Old Feb 17, 2007 | 01:29 PM
scoot's Avatar
scoot is an unknown quantity at this point
Default Rear Defrost
My rear defrost is not working. When I push the button the light does not come on any more and neither the rear window or the side mirrors heat up I checked the fuse and put a new one in and nothing it was a 30amp fuse if I was checking the right one any other ideas.
Thank You
Old Feb 17, 2007 | 02:23 PM
hillbillyinOhio's Avatar
Default RE: Rear Defrost
get a DMM and check for power at the switch and at the leads in the back. might be a loose wire or someting.
Old Feb 18, 2007 | 04:54 AM
Chevy Lover's Avatar
If you fix the defogger, that should also fix the heated mirror problem. It could be loose wiring, a relay or the HVAC control module.
Do you know the a/c RPO, is it C68?
Old Feb 18, 2007 | 12:22 PM
Ac RPOs are from C60 - C69
88s10Blazer
Sep 11, 2013 02:41 PM
ratrodsare4ever
Apr 12, 2011 08:57 PM
94BlazerPA
May 17, 2010 08:32 PM
tscott
Oct 26, 2009 09:23 PM
kakn
Dec 12, 2006 01:04 PM
