rear door panel removal- help?
Old Feb 5, 2005 | 04:23 PM
pusher_sr's Avatar
pusher_sr is an unknown quantity at this point
Default rear door panel removal- help?
i've got a rattle in my left rear door and was about to remove the panel but thought i'd better ask before i crack a $50 piece of plastic. any tips on what to look out for in the way of plastic clips or hidden screws? thanks. pusher senior
Old Feb 5, 2005 | 09:59 PM
01xtreme's Avatar
01xtreme is an unknown quantity at this point
Default RE: rear door panel removal- help?
When I removed mine there was two screws underneather the arm rest door handle. The rest of it should just pop off. Use one of those door panel removing tools for clips or a screwdriver. Be careful though. Mine was kinda hard to get off. I THINK that the top of the panel slips in at the top by the window. (I can't remeber exactly). Once it's off, just unhook the wiring harness for you power locks/windows (if you have any). That should pretty much do it.
Old Jan 24, 2006 | 07:49 PM
camohog1's Avatar
camohog1 is an unknown quantity at this point
what year is your blazer? im not sure if this would help or not, but I dont think they are all the same. On my 91 once you undo the surface panel screws,you should just be able to lift the panel up straight from the window. There may be a piece of window stripping that may need to be undone first.It should lift just straight up and at this point you should be able to move the door panel up and down as well as slide it around in a circle. If you have manuel windows, there should be a little piece that looks like a "c" it is a clip that holds it on there. Simply use a straight screwdriver to remove it, then once it comes off there should be some big connectors that look like circles, (mine are black i dont think color matters) that have a screw in the middle of them, just undo those and you should have unlimited access to the inside of the door panel.
Old Jan 24, 2006 | 07:58 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
My 03's panels come off as 01extreme has defined. There was also a philips screw behind the door handle, but that's it. It does go over a lip by the window. There are these little white plastic gromets that pop onto the metal door. Just pull and they come right out.
ckroll98
Aug 26, 2013 06:44 PM
scosentino88
Jun 3, 2012 07:12 PM
bp2935
Feb 2, 2008 02:25 PM
gizwilly
Jan 18, 2007 09:47 AM
john65807
Jan 7, 2006 11:31 AM
