rear ebrake hardware.........
Old Mar 25, 2012 | 04:47 PM
coolen's Avatar
coolen is on a distinguished road
Default rear ebrake hardware.........
Well I attempted to put in new hardware on my rear brakes. However, while attempting to take out that small screw that holds the top clip out...I broke it off and now I'm not sure what to do. It doesn't look like an easy fix.....any suggestions?
Thanks
99 Jimmy, rear disk.
Old Mar 25, 2012 | 05:12 PM
Rottidog's Avatar
get an Eazy Out set, drill it for the appropriate size easy out & extract it. Get a new parking brake hold down kit - $3.42 at rockauto for 2/each side & replace them both.
If you have access to a TIG welder, weld another bolt on top of the broken bolt stem, let it cool, soak it with penetrant like Seafom Creep & remove it that way. I say TIG welder because that bolt is tiny & I doubt you'd get a MIG to weld a bolt on it without welding it to the truck.
Old Mar 25, 2012 | 06:12 PM
newguy's Avatar
Or drill it out and re tap it
Old Mar 25, 2012 | 06:17 PM
xgiovannix12's Avatar
yea its gonna be hard with a mig
Old Mar 25, 2012 | 07:37 PM
newguy's Avatar
Or if you can get some vise grips on it, try heating it with a torch
Old Mar 26, 2012 | 08:22 AM
spittybays
Guest
Posts: n/a
I'm With Joker, clean and easy.
Brian_D
Mar 19, 2014 09:40 PM
Keystoneguy91
Oct 30, 2012 08:44 AM
Black99blazer
Mar 1, 2012 06:35 PM
_HeC_
Oct 26, 2011 08:03 AM
rodono
Mar 9, 2011 09:50 PM
