Rear glass totally broken, can it be replaced?
Old Jan 5, 2011 | 10:35 PM
blazermazer's Avatar
blazermazer is on a distinguished road
Default Rear glass totally broken, can it be replaced?
I got rear-ended today and the blazer isnt on me (to check if the 2 long hinges arent bent, dont think so), but since the glass is more or so attached to those 2 hinges that go up and down, should those 2 hinges being undamaged be enough for a glass person to come out and replace it? Right now I have cardboard up My frame was pushed in a bit, the tailgate part...but I dont think that matters as far as keeping glass from being put on. Thanks for your help.
Old Jan 5, 2011 | 10:46 PM
ABN31B's Avatar
so long as the tailgate portion is straight where the glass butts up to it, then yes, new class can easily be re-attached.
you can probably get it cheaper if you just grab on at the Junkyard (depending on your year).
if your "frame is pushed in a bit" you may have bigger problems than just the glass though...
Old Jan 5, 2011 | 10:50 PM
@abn31b - thank!
The frame is pushed in enough where the wheel-on-gate cant even lock, its pushed in where I cant even push it to lock anymore...it SEEMS all it needs is an inch or less pushed in to click the lock but I cant even do that...So im guessing im really in for it heh
Old Jan 6, 2011 | 12:44 AM
ABN31B's Avatar
OH! the frame for the glass!!!
I thought you meant the frame as in what the chassis bolts down too....
if it's the whoel back hatch or tailgate/glass you could probably get the ENTIRE thing from a JY (with a little searching) for a lot less than you'd think.
chevyblazer
May 22, 2014 03:15 AM
mr.vls
May 4, 2013 09:59 PM
OldBetsy
Jun 28, 2012 12:59 AM
scosentino88
Jun 3, 2012 07:12 PM
j_man1990
Apr 7, 2007 02:26 PM
