Replaced Rear Glass Pushbutton
Old May 3, 2013 | 12:13 PM
mr.vls's Avatar
Default Replaced Rear Glass Pushbutton
Today I replaced my rear glass pushbutton because the glass would open from the dash and the remote but not from the pushbutton. It was fairly straight forward, remove the inside panel, remove the mounting plate below the button, slide the retainer off the pushbutton and disconnect the electrical connection. Installation is the reverse of removal. The only thing you have to be aware of is that there is a retaining screw that is located behind the glass in the liftgate at the lock area for the inside panel.
Old May 3, 2013 | 03:51 PM
Diaita's Avatar
Thanks for sharing! Is this for a first gen, or second gen Blazer?
Old May 3, 2013 | 04:07 PM
mr.vls's Avatar
2000 GMC Jimmy - 2nd Gen
Old May 3, 2013 | 08:48 PM
AJBert's Avatar
Where did you acquire said push button? I've had this problem for a few years now.
Old May 3, 2013 | 10:58 PM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
You can get them anywhere... Advance Auto Parts, Auto Zone, O'Reilly's, etc. They're not difficult to come by. If those don't work, there's plenty of places online which sell them.
The procedure is more the same for any other switch on that panel.. I had to replace my headlight switch. Just remove the two screws in the panel above the instrument cluster, and the whole bezel pulls out. Then you disconnect the connectors for the 4x4 and the switches on that panel (head and parking lamps, rear hatch button, panel dimmer), pop out the switch you're replacing, and just pop the new one in. Mine had one unused panel, so I drilled through it to mount the switches for my headlight and taillight wig wags.
Old May 4, 2013 | 04:44 AM
mr.vls's Avatar
I purchased my switch from a local chevy dealer.
Old May 4, 2013 | 05:19 PM
AJBert's Avatar
Ummm...this is about the push button on the tail gate, not the dash.
Old May 4, 2013 | 09:59 PM
Okay. It's still not particularly difficult to find those.
shayne391
Dec 10, 2013 07:13 PM
scosentino88
Jun 3, 2012 07:12 PM
blazermazer
Jan 6, 2011 12:44 AM
BlazinBlazerZR2
Jun 3, 2009 05:22 PM
cowboy35002003
May 29, 2008 09:05 PM
