Rear hatch keeps blowing fuses
Old Aug 25, 2007 | 02:21 PM
Psygnosis's Avatar
Psygnosis is an unknown quantity at this point
Default Rear hatch keeps blowing fuses
I have a '99 Jimmy and I've been having problems with the rear glass blowing the fuse. I doesn't seem to matter if I use the button on the dash or the remote, the glass will open but after a few uses, the fuse goes and the glass wont open and it takes the power door lock buttons on the inside with it. Has any one else experienced this, or know how to fix it? Or do I just have to try to find a short somewhere. In the meantime I just pulled the relay and this keeps the fuse from blowing, but I can't open the glass.
Old Aug 25, 2007 | 07:44 PM
Default RE: Rear hatch keeps blowing fuses
Sounds like you either have a failing glass latch actuator or a short in the system. Electrical gremlins are quite difficult to nail down...
Old Aug 26, 2007 | 09:13 PM
ERUKOLINDO's Avatar
ERUKOLINDO is an unknown quantity at this point
I had this same problem in my 96. took me a month and a million fuses. it was my cig lighter.
the original had went out, and i replaced it with a fancy one from pep boys. for some reason it kept shorting that fuse.
hope this helps.
Old Aug 27, 2007 | 07:29 PM
Psygnosis's Avatar
ORIGINAL: ERUKOLINDO
hope this helps.
I don't think it's anything like that. It only blew the fuse when I would try to open the hatch and since i pulled the relay it's hasn't blown any more fuses (and the hatch doesn't open either). So there's a good chance it might be the acutator, I just need to decide if it's worth trying to fix.
nineteensixtycaddy
Sep 12, 2010 08:54 PM
1baggedblaze
Apr 13, 2010 04:52 PM
bensale56
Apr 29, 2009 06:07 AM
jayco3399
Feb 10, 2009 06:16 PM
03tb
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Sep 5, 2007 01:14 PM
