Rear Hatch won't open?
Old Nov 22, 2011 | 11:52 PM
c0d3m0nk3y's Avatar
c0d3m0nk3y is on a distinguished road
Default Rear Hatch won't open?
I was transporting a transmission and dumb *** me didn't think it needed to be strapped down, so long and behold a sudden stop made it roll and when it rolled back it slammed right into the tailgate. From that point the hatch wouldn't open, I'd hear the actuator go but it wouldn't unlatch. After a week of searching online I found 3 forum posts on multiple sites saying the same and with people graciously thanking them. Well maybe they changed something mid gen but in my 2000 Blazer 2 door it did not. In the process I did figure out how it should be done and luckily I only broke 2 panel pins in the process, only because I started the wrong way.
First of all you wanna make whatever room you can back there, 4L60E + "300lb man" + "trying to fix hatch" = "Breaking the window seems like a good solution"
Take a 15mm open box wrench, the smaller the better, and unbolt the latch hardware from the glass. You'll be able to access the 2 bolt heads from each side of the hump. This is tedious but yanking back on the panel til it pops does not make it much easier and you'll just break the pins. Now you can open the glass.
Now it's time to get the latch out, good news that's done from the outside. Take out the small screw on the top left of the hump. Now gently push on the panel until you hear a couple pins pop, as long as you don't go He-man on it you should get 1-2inches of clearance without breaking any of the panel pins.
Behind, and slightly below, the latching mechanism you'll see a piece perpendicular to the latch and makes an L with it. Take a flat screw driver and push down on it at the joint. Once that pops the glass side of the latch will release and now you can open the tailgate.
The hard parts done, have a smoke and/or drink a beer if you hadn't already been doing that. With the tailgate open you can now take out the 2 screws on either side and finish popping the panel out. Now take the hex screws holding the inner panel and remove it, carefully because the actuator is mounted to it.
Now if the actuator needs to be replaced, the only replacement I found was through a dealership for about $60. If it's fine and it just wasn't engaging you can buy the Dorman 42426 Rear Window Actuator Kit which is an improved hook up than stock.
Hope this saves someone from the headache I had figuring it out
Old Nov 23, 2011 | 02:04 PM
hzl6cm's Avatar
hzl6cm is on a distinguished road
Unless you you backing up hard and jammed on the brakes, braking wouldn't have made the transmission roll backwards. Now on the other hand, sudden, hard acceleration would do it (ask me how I know, it might have something to do with launching a full cup of coffee from the cup holder to the passenger seat of my '04 Z06 Corvette early one morning and having it all drain through the perforated leather in to the seat foam before I could do anything about it!).
Old Nov 24, 2011 | 12:58 PM
c0d3m0nk3y's Avatar
Trans tipped forward and when the suspension tension settled back that caused the trans to roll back
4x4blazerguy
Nov 6, 2012 10:22 PM
Wexinlo
Jun 8, 2012 02:46 PM
Blake726
Sep 11, 2011 05:56 PM
Major Tom
May 23, 2011 12:34 PM
Kellen
Sep 21, 2006 12:44 PM
