None stop blinker relay
Old Nov 23, 2011 | 04:11 PM
stark05's Avatar
stark05 is an unknown quantity at this point
Default None stop blinker relay
My blinker sound is none stop. The blinker lights only run when I put the turn signal on. But the little relay under the glove box is always going. Tick tick tick tick tick tick tick. You get the picture! What is causing this? How can I fix or by pass and still have functioning blinkers? I'm going nuts!!
Old Nov 23, 2011 | 06:46 PM
warthogdriver's Avatar
you can try swapping out the turn signal relay itself...but when mine did this it was the multi function switch on the column that went bad and shorted out.
pricey part but not too bad to swap out.
if you do go for that there are a couple of how to's floating around here.
i am sure others will chime in here and help you out too....my guesses are based only on my own exp/issues.
Old Nov 23, 2011 | 07:07 PM
Please list your vehicle info.
For the 98+, this is most often caused by the hazard switch in the column. This is especially true if the ticking stops when the brake is pressed. Try messing with the hazard switch on top of the column. If you can lightly press it in or push it to the front/back/side and the ticking stops, a new hazard switch might be the only repair you need to make. There is a Tech Article on both the hazard switch replacement as well as the entire multifunction switch replacement. You can find a link to the index in my signature below.
Old Nov 24, 2011 | 04:35 PM
stark05's Avatar
2000 blazer 4wd
Old Nov 24, 2011 | 04:48 PM
xgiovannix12's Avatar
push the hazzard switch a tad forward or backward
not to much just enough so you dont break it
see if the click stops when you do so
Old Nov 24, 2011 | 05:12 PM
Hmm. Exactly what I said except without the Duke brother's county.
Old Nov 24, 2011 | 05:19 PM
oh lol i didnt see your above post kyle sorry
blazintexas
May 1, 2012 06:01 AM
phate422
14
May 24, 2011 09:36 PM
ecmusicman
Jun 28, 2010 11:31 PM
chipjumper
Jun 17, 2010 12:24 PM
SDimeBlazerlady
Jan 27, 2007 05:58 AM
