Rear license plate lamps and turn signal
Old Feb 22, 2014 | 11:11 AM
RandyRhoadsFan82's Avatar
RandyRhoadsFan82 is on a distinguished road
Default Rear license plate lamps and turn signal
My 99 Jimmy SLT will not illuminate the license plate lamps at night unless the trailer harness is plugged into a trailer.
Just recently, possibly due to the crappy Wisconsin weather, my right turn signal blinks really fast. On the tail light, the top bulb illuminates, but the next one down doesnt. Here's the kicker...that second bulb down will illuminate when I press the brakes.
Where should I start with these two, is the ground located in the same place where the trailer wiring is?
I also have a "t-one" connector like this.....
http://www.hitchcorner.com/t1conect.gif
not the same female connectors on it, but will it work on the Jimmy? I bought it for a Chevy S10, 95' and it plugged right in.
Thanks guys
Old Feb 22, 2014 | 07:03 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
Start with replacing the bulb that does not blink, when it is flashing fast means bulb is burnt out.
Old Feb 22, 2014 | 07:49 PM
I already swapped it with a good bulb and it still did the same thing. If it was burned out, it wouldn't illuminate when the brake comes on, which it does. Possibly a bad ground?
Old Feb 22, 2014 | 09:38 PM
You might have two problems going on back there. For the tail light, it could be a bad ground in the socket, (which requires a new socket). The license light definitely sounds like a bad ground, or shorting out with the trailer wiring.
EDIT: Little trick from way back..... turn on the parking lights and the 4 way flashers. Watch the lights in back, you can usually see which one is messed up by comparing it to the other side, gotta blink in sync.
vortec bowtie
Jun 28, 2012 12:55 PM
dg98adams
Mar 1, 2010 10:19 AM
ta3ff
Oct 14, 2009 05:07 PM
pbd3mon
Dec 29, 2007 08:24 PM
Jhop16
Oct 9, 2006 09:10 PM
