Rear Powerless Window
Old May 6, 2010 | 06:36 PM
blzR's Avatar
blzR is an unknown quantity at this point
Default Rear Powerless Window
I had to manually hooked up a spare battery and wires to the rear window connections
to get window back up(went up with ample power,so i'm positive Window motor is good)
Any simply fixes? didn't find any corrosion on either front or rear
switch connections when popped out..tried giving both doors some whacks and driving over a rubble strip to see if connection(s) would return,but nothing.
Old May 6, 2010 | 06:45 PM
Here's the wiring diagram (attached). With the diagram, you should be able to troubleshoot the switches to make sure that they are working properly as well as check for power & ground where appropriate for a given function.
Old May 7, 2010 | 08:58 PM
ronaldo's Avatar
ronaldo is an unknown quantity at this point
Default My switch was bad
I had the same problem that was caused by a bad switch. When I moved the switch to the other door, the problem followed it. Even the switch on the drivers door won't work.
Old May 10, 2010 | 10:57 AM
blzR's Avatar
I still haven't been able to get to this window issue,but i hit pay dirt yesterday after another visit to the afore mentioned 'rumble strip' hospital run on the side of the highway
..such a nice affordable medic that Mr.Rumble!
e602
91
Mar 8, 2015 04:53 PM
GolfClapperX
Jun 5, 2009 03:48 PM
Valafar
Mar 30, 2009 07:49 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
sleonh
Mar 29, 2005 03:32 PM
