Rear Window Trim Removal?
Old Aug 21, 2016 | 06:11 PM
LannyL81's Avatar
Default Rear Window Trim Removal?
This is on my '02 4dr; anyone know how to remove the rear grills(or whatever they are called) and trim around the rear side glass? I have rust under the paint at the top rear corner of each side glass which I would like to attend to. I found the three plastic rivets on the inside where the rear glass gas struts reside....I removed them but there are some type of clips that hold the "grills" on which I could not figure-out how to get them to release.
As far as the rear side glass trim....is it glued on?....I could not find any clips and did not want to push my luck and break the trim by lifting it up much.
Appreciate any insight or assitance.
Thanks
Old Aug 22, 2016 | 06:35 AM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
as far as the 2 side pieces, they do come off..have taken them off before..use care and you'll 'pop' them off..your 3 clips and then possibly an upholstery tool or the like-to pry off... Around the windows..now never attempted that although I doubt it comes off..good luck! Jerry
blazerguy22
Mar 30, 2019 09:47 AM
tycobb280
May 10, 2011 08:45 PM
okvortec
Dec 8, 2009 06:25 AM
blazerguy22
Oct 13, 2009 02:54 PM
brunosrk
Nov 18, 2007 10:21 PM
