Rear Wiper washer sprayer
Old May 24, 2010 | 01:15 AM
davedidit's Avatar
davedidit is on a distinguished road
Exclamation Rear Wiper washer sprayer
Rear Wiper washer sprayer not workingis their a fuse for the pump
or a fried pump?
broken line?
anyone got feedback
99 S10 4 door
were do I start looking
K&N
Flowmaster
1.5" rear shackle
TB cranked
31x10.50x15 BFG Mudd TA's
Old May 24, 2010 | 01:25 AM
DaveHearne's Avatar
DaveHearne is on a distinguished road
If you can hear the pump working it's probably a blocked nozzle or a broken line.
Wouldn't mind betting that if you lift up the plastic trim in front of the lower tailgate you will find the space underneath is full of fluid & the little rubber elbow joining the pipe has come off where it goes through the rubber conduit leading to the tailgate. This seems to be a common problem - it happened to mine. When mine stopped working I was mystified....until I searched this forum & found out how common it was. I ended up pushing the connection back together & putting small clips around it to hold things in place. I then had to remove the carpet & dry things out as it was soaked underneath.
Left me wondering why they had to run the pipe inside the vehicle? At least if it ran underneath the body it would be easy to spot leaks & the carpet would stay dry!
Old May 27, 2010 | 11:35 AM
davedidit's Avatar
Thanks for the feedback
no sound from the rear pump
were is it at ?
line good behind the interior panel
does it get the washer fluid from the main tank?
and were does the hose line run
just trying to make everything work on it
the 99 S10 Blazer was A gift with a dead 4L60E
1.300 for the compleate tranny rebuild its great
have recept from the New GM Crate 4.3L 41k on it not a rebuild
run Castroil 10w30 senthic oil in the crank case
rebuilt rearend 30k
new neo bushings upper & lower in front end
and Black aloy rims and 31 x 10.50 x 15 BF Goodrich Mudd TA's last week
their went another 1.300 bucks!
K&N air filter and Flow Master
16 mpg around town
21 mpg Highway
so for under 3.000 bucks I have a smooth ride
well it's nor that smooth with the hard bushungs
and the ProComp 3000 series shocks I put on it
a few other things to fix dam seat reckiner handles
passanger left window regulator
and the GM stereo must GO!
thanks for any help on my wiper spryer
Dave
Las Vegas NV.
Old May 27, 2010 | 11:56 AM
DaveHearne's Avatar
Hi, the pump is on the same tank as for the front washer, can't remember without looking but I think it's the lower one out of the two. Mine is a right hand drive export model so it may be slightly different underhood. Easiest way to check if the pump is at fault could be to maybe swap the wiring connectors between the pumps & see if the other one runs? The pipe runs underneath carpet somewhere but i'm not exactly sure where.
Old May 29, 2010 | 11:00 PM
blazerboy001's Avatar
blazerboy001 is on a distinguished road
It's probably the hose in the tailgate. thats what my problem was. If you keep pumping it, you will know eventually, because there will be a big puddle under the back of your truck. lol
Old May 30, 2010 | 06:49 PM
davedidit's Avatar
thanks i'll keep looking
racechaplain
14
May 13, 2014 05:42 PM
Helter80
Jun 14, 2013 08:34 PM
truesmack
Dec 13, 2009 04:33 PM
carlo
Jan 1, 2007 03:03 PM
jboy76
Jun 7, 2006 09:25 PM
