rearend noise
Old Apr 21, 2012 | 08:52 PM
noxendine4u's Avatar
noxendine4u is on a distinguished road
Default rearend noise
96 blazer S10. Have alot of whinning out of the rearend. looks like it has a new tranny in it. all the u-jionts and d.shafts are good any suggestions? Could the gear ratio be off or what, bearings?
Old Apr 21, 2012 | 10:48 PM
When does it whine?
Acceleration, deceleration, or maintaining a steady speed?
Old Apr 22, 2012 | 07:28 AM
Thanks for the reply. I'm new at this. It whines the faster you go. It seems to be vibrating when going slow. Like the gears are meshing really hard, (ring and pinion) i don't know. The vibration seems to me to rule out bearings. Could it do that with the rearend gear not matching the tranny?
Old Apr 22, 2012 | 11:45 AM
If the whine happens all the time, acceleration, deceleration, and maintaining a steady speed, and is speed related, it could be side bearings, pinion bearings, or as you mentioned, ring and pinion not meshing correctly. Noises can be difficult to identify, even with a trained technician. The vibration could be worn/loose pinion bearings, they can also cause a whine. The differential will need to come apart to determine exactly what the problem is, and repair it.
Old Apr 22, 2012 | 06:03 PM
Default rear transfer case
96 blazer LT. iI look at the drive shaft and noticed that the tag on the rear transfer case says 272 ratio. Could that cause the whining noise that i hear?
Dallas1970
Feb 22, 2019 05:05 PM
lt170chevelle
Dec 14, 2009 12:18 PM
DFINE160
Dec 7, 2009 12:17 PM
countilaw
Feb 21, 2008 08:44 PM
BlazerLS95
Jan 15, 2005 06:47 PM
