bldg a 46 on a 87 S-10 Frame-- Need rearend help
Old Feb 21, 2008 | 07:10 PM
countilaw's Avatar
countilaw is an unknown quantity at this point
Default bldg a 46 on a 87 S-10 Frame-- Need rearend help
I'm building a 46 Chev 1/2 ton pickup on a 87 S-10 Frame with a SBC 350 (5.7) tied to a TH350 Auto trans. I want to replace the 87 rearend with a later model Blazer with disks. A stronger rearend than the 87 S-10 that I now have.
So---- What year rear end am I looking for. How can I identify the correct rear end in a junk yard. What year Camaro would work?
Frank[sm=smokin.gif]
Old Feb 21, 2008 | 07:27 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: bldg a 46 on a 87 S-10 Frame-- Need rearend help
go on ebay do a search for sellername (s10warehouse) hes got all kinds of diff rears for these trucks...
Old Feb 21, 2008 | 07:42 PM
thegr81's Avatar
Just get anything with a limited slip rear end and you will be fine!! Question for you though if your building that truck from frame up why not build your own frame?? Just a Question ??
Old Feb 21, 2008 | 07:52 PM
countilaw's Avatar
The S-10 Frame is a natural for this swap. It has the right wheel space, width, lenght and engine mounting. It has a modern suspension. The front does not have to be changed. Normally the rear end is sufficient, but not with the high output engine that i am using. So it's cheaper to use the S-10 frames and save a lot of time.
Frank
Old Feb 21, 2008 | 07:53 PM
2002XTREME's Avatar
I`m doing the same basic thing but i`m putting my 1949 ford p/u body on an s10 frame its gonna have a 454 in it.. right now the truck has a corvette 327... I need power...
Old Feb 21, 2008 | 08:39 PM
thegr81's Avatar
Ok sounds reasonable then, one suggestion is to make sure you box the whole frame for extra support and strength!!
Old Feb 21, 2008 | 08:42 PM
2002XTREME's Avatar
o most def its gonna be boxed, right now i have that motor in my 84 elcamino and it has ***** to the world its got roughly 600 hp with a turbo 350 tranny with quite a bit of work in it,,,,
Old Feb 21, 2008 | 08:44 PM
thegr81's Avatar
Right on, sounds like its a blast to have!!
Dallas1970
Feb 22, 2019 05:05 PM
MrDave14
May 4, 2011 09:40 PM
lt170chevelle
Dec 14, 2009 12:18 PM
DFINE160
Dec 7, 2009 12:17 PM
BlazerLS95
Jan 15, 2005 06:47 PM
