Recharge 95 Blazer A/C
Old Jun 13, 2009 | 05:49 PM
  #21
Crestwood1001's Avatar
Crestwood1001 is on a distinguished road
If my system is completely empty and the compressor does not kick on how do I had freon?
Old Jun 13, 2009 | 07:30 PM
  #22
Have you read any threads on this subject? Try checking out the Tech Article (DIY) section. Another member wrote up some very good articles on the subject of A/C.
Old Jul 12, 2010 | 12:08 PM
  #23
harris69's Avatar
harris69 is on a distinguished road
Default 99 chevy blazer
how do I install a new evaporater
Old Jul 12, 2010 | 12:11 PM
  #24
harris69's Avatar
put in a jumper wire on the switch until it works on its on
Old Jul 14, 2010 | 07:25 PM
  #25
noobieblazer's Avatar
noobieblazer is on a distinguished road
good insturctions 96blzer nut i have the same exact model and everything for some stupid reason i was doing wrong hence the term noobie
Old May 24, 2014 | 08:58 PM
  #26
pventuri81's Avatar
pventuri81 is on a distinguished road
Originally Posted by carterx
The silver canister at #1 is not cold/cool at all. Top and bottom it's very warm. What I'm sure is the compressor #3 is running. The pressure is still sitting around what I left it at. I did some driving around today and turned the A/C to it's max and the pressure is the same which tells me it's not leaking but though I drove a fair amount it's still putting out nothing but hot/warm air.
So is #2 the lower ac orifice hose where i hook up the freon to im new to this ive added freon to vehicles before but not sure if that is the right one or is number 1 where it goes
Attached Thumbnails Recharge 95 Blazer A/C-addadadadad.jpg
Old May 25, 2014 | 12:00 AM
  #27
Blazer_4x4's Avatar
Blazer_4x4 is on a distinguished road
The #2 in that picture is the high pressure side (liquid refrigerant) line, You should only charge the system on the low pressure (suction) side of the system, which is the #1 in your picture. If you're going to use one of those cheapo single blue hose auto-parts store set-ups that's attached to the can then the blue hose on the 134a refrigerant can will only connect to the correct low pressure fitting, it won't connect to the high pressure fitting because they're different sizes.
Jello0123
Jun 11, 2009 01:34 PM
abadinalbany
Jun 1, 2009 08:27 PM
brf2
May 19, 2009 07:56 PM
blazerlt01
Jun 18, 2007 07:51 PM
hockeykid15
May 7, 2007 10:02 PM
