Relocating O2 sensor help
Old Jul 19, 2018 | 05:15 PM
Default Relocating O2 sensor help
Hi all,
I'm looking into my options for dealing with a catalytic converter I was sent that has the O2 sensor hole in the wrong place.
A local shop said they could cut a hole and install a new set of threads for installing a new sensor where it should be. However I'm having trouble finding a screw-in plug for the mis-placed hole.
Does anyone have any ideas for how to plug the mis-located O2 sensor hole?
BTW, I am waiting on a reply to my complaint from the part supplier. My inquiry of you all is in support of my back-up plan.
Thanks,
Christine
P.S. Here are the new and original cats next to each other. On the new one, the O2 sensor would be positioned where it would hit the underside of the body (instead of to the side) and prevent the cat from being high enough to bolt on to the muffler.
Old Jul 19, 2018 | 08:52 PM
Rusty Nuts's Avatar
There are plugs for the o2. Is that the wrong part for your application or do you think it's your suspension lift?
Old Jul 20, 2018 | 12:55 AM
Yes, I've found the plugs online but there are none at the local stores. Otherwise I might used one and then had a local shop install a new bung fitting in the correct location.
As for the suspension lift, that is not it as the exhaust is hung off of the frame and thus the body to frame clearance is unchanged. It is just that they put the hole and threads for installing the O2 sensor in the wrong location. Grrr. LOL
Old Jul 20, 2018 | 09:18 AM
LesMyer's Avatar
Ace Hardware has them (at least mine does) - is sold as a automotive drain plug in their specialty nuts/bolts drawers. I have one right now that I'm not using anymore, but that doesn't do you any good!!
Old Jul 20, 2018 | 09:30 AM
Of course! Thank you. I knew I had seem those plugs somewhere. They were under my nose, under the car, the whole time.
Old Jul 20, 2018 | 01:04 PM
I would cut that bung out, weld it in the proper location, and weld a small patch over the leftover hole. No reason your muffler shop can't do the same.
RoxStar33
Dec 21, 2012 08:28 PM
19jimmy99
Mar 27, 2009 09:05 AM
Miget_in_japan
May 28, 2008 08:24 AM
danmiranda
Apr 3, 2008 09:49 PM
JoeRock
May 25, 2007 07:27 PM
