Reman Caliper different?
Old Oct 12, 2010 | 08:26 PM
88skisupreme's Avatar
88skisupreme is an unknown quantity at this point
Default Reman Caliper different?
I bought a remanufactured caliper for the rear driver side from NAPA and the bleeder valve is on the bottom, not the top. Since they close earlier I checked at Advance Auto Parts and theirs was the same way. Is this right or are both places getting it wrong? It looks like NAPA is using the same part number for the left and right are they interchangeable?
Old Oct 12, 2010 | 08:47 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
I would check and see if that was packed wrong...in other words-is the one you have for the right rear. Hold it up to that side-check it, that's my thought. Any caliper that I've put on has been exactly right(bleeder in the right spot)-even if a re-man. Jerry
Old Oct 12, 2010 | 08:52 PM
I dont think the parts stores care which side it is, I just looked up Autozone for the hell of it and they have this in the parts description: "Driver sidePart number may fit opposite side on some models"
Old Oct 12, 2010 | 09:19 PM
LS Twins's Avatar
LS Twins is an unknown quantity at this point
I believe if you install the caliper on the wrong side it will not bleed and you will not get/have any pedal -imo. yes there is a difference though it will bolt up.
Old Oct 12, 2010 | 09:26 PM
blazerpower's Avatar
blazerpower is on a distinguished road
you should try a different year and see if its any different
Old Oct 12, 2010 | 09:43 PM
NVANZEE's Avatar
it sounds like the gave you one for the wrong side. I got remans from napa and they were the right ones. The bleeder has to be at the top or you wont be able to bleed all the air out
Old Oct 12, 2010 | 11:33 PM
Went to O'reilly and got one for the other side, I was planning on doing both sides eventually anyway. I guess the lesson is know your parts.
Hiney
Dec 19, 2011 11:07 AM
rcravincase
Jan 7, 2011 08:34 PM
rcravincase
Sep 23, 2010 08:10 PM
thereverendbill
Jun 19, 2010 10:12 PM
mchap87
Jul 24, 2009 04:02 PM
