removeing the torsion bar bolt?
Old Apr 26, 2008 | 05:07 PM
20injimmy's Avatar
20injimmy is an unknown quantity at this point
Default removeing the torsion bar bolt?
ive searched and couldnt find it anywere. im gonna lower the front by back off the t-bar bolt. i read that someone said to just take it out all together and some said to back it off 8 turns. so what would happen if i did just remove it all together im lookin for the lowest drop with out spindels. can some one pzl help me out.
thanks mario
Old Apr 26, 2008 | 06:05 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: removeing the torsion bar bolt?
If you are going to take the torsion bars out completly you will need to have some other suspension mods otherwise you are going to eat front end parts .
Old Apr 26, 2008 | 07:31 PM
I think he meant just remove the bolt.
Anyway, follow the torsion bar towards the rear of the vehicle. It will go into a crossmember. Look around on the underside of this crossmember for the two bolts (one on each side of the vehicle near each torsion bar). The bolts that you need to mess with will be towards the inside of the vehicle when looking at the underside of the crossmember.
Old Apr 27, 2008 | 12:14 AM
blazin97's Avatar
blazin97 is on a distinguished road
Just taking it out will drop you about 2 inches.
Old Apr 27, 2008 | 02:15 AM
20injimmy's Avatar
i was meaning just the bolt itself.
ok thanks guys, i already dropped it but left the bolts after i took them all the way out. then i just put them back in finger tight. its ok just to leave them out or just leave them in like they are?
Old Apr 27, 2008 | 03:41 AM
blazin97's Avatar
I'd take them out, they are ok out.
Old Apr 27, 2008 | 12:14 PM
95_4door's Avatar
95_4door is an unknown quantity at this point
If you take them out, the torsion arm will rest on the threaded plate that the bolts go into. It won't hurt anything.
Old Apr 27, 2008 | 02:02 PM
As those above have suggested, I would remove them if you don't actually have tension on them. There is no harm in leaving them sitting on the threaded plates.
Tinted
Apr 4, 2011 10:00 PM
PaulO2288
Mar 19, 2010 03:18 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
rlt7272
Suspension Tech
Mar 9, 2007 02:20 AM
thevair65
Jan 31, 2007 02:02 PM
