removeing door stripping
Old Jan 30, 2007 | 11:23 PM
thevair65's Avatar
thevair65 is an unknown quantity at this point
Default removeing door stripping
i would like to remove the rubber door stripping. i dont like it. ive heard alot of ways to do it but on alot of differant vehicles so i would like to know the best way to remove it on my truck.
thank you
Old Jan 30, 2007 | 11:33 PM
Chevy Lover's Avatar
Default RE: removeing door stripping
The best way that I know of is to use a body shop eraser on the end of a drill. Just don't use to much pressure or to much speed or you will burn through the clear coat.
You can buy body shop erasers at most parts stores.
I just re-read your post, I thought it was the pin striping you were talking about, but it's actually the body side mouldings if they're rubber.
You should be able to get an edge loose with a knife blade and then just pull it off. After that you still need to clean up the adhesive the same way I just described with the body shop eraser
Old Jan 31, 2007 | 12:15 AM
thevair65's Avatar
ok cool thanks for the help. ill give it a try.
Old Jan 31, 2007 | 12:43 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
I did that to my 92 S10. I just pulled off the molding, and then I used PB Blaster and alot of elbow grease to get the adhesive off. It worked well and it was cheap. Korey.
Old Jan 31, 2007 | 04:59 AM
thevair65's Avatar
my smoulding has chrome stripping is that going to be an issue?
Old Jan 31, 2007 | 09:44 AM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
No, you got the same thing I do. I am planning on doing it to mine when it gets warm.
Old Jan 31, 2007 | 02:02 PM
thevair65's Avatar
cool. i hate that stuff its like granny stripping i cant wait to tear it off
PaulO2288
Mar 19, 2010 03:18 PM
kurslt
Oct 14, 2009 06:21 PM
20injimmy
Apr 27, 2008 02:02 PM
dusted800
Detailing
Mar 31, 2007 12:05 PM
alphagtp
Mar 10, 2007 10:49 PM
