Removing fuel lines..."how to get over the hump".
Old Jan 10, 2011 | 04:48 PM
The89Blazer's Avatar
The89Blazer is on a distinguished road
Default Removing fuel lines..."how to get over the hump".
2 door blazer, figured after replacing everything, i noticed the lines were pretty bad around the back of the frame where they turn for the pump...well got everything free with zero issue, clips off and all using a small screwdriver...yet im not sure how to feed the fuel lines threw the "hump" to actually get them out from the under carriage?....Figured that would be the easier part.
I did search, nothing came up.
Old Jan 10, 2011 | 06:59 PM
37 views?...Im sure someone has figured out a recommended way to do this other then having to lift the body off the frame, from which ive read?....Im i missing something?
Old Jan 10, 2011 | 09:23 PM
Please be patient and WAIT for responses. DO NOT bump a post after waiting a measly 2 hours and 11 minutes. Waiting 24 hours is required by the rules of the forum.
You may want to define "hump" a little better.
Old Jan 11, 2011 | 03:59 PM
Its a 2 door blazer, the section of gas line that i was going to replace runs from the fuel filter to the nylon hose that would complete the connection to the sending unit in the fuel tank. The area of difficulty is in the wheel well where the line is run, and the chassis goes up. Cant push or pull the lines out because of the "L" structure.
skarphace
Sep 6, 2012 02:59 PM
K5-Mike
Aug 31, 2011 11:01 PM
mudcat
20
May 4, 2011 05:47 AM
pmzusmc
Apr 19, 2011 05:44 PM
jambalaya
Aug 31, 2010 12:34 PM
