Removing plug from 2000 differential
How do you remove the plug from the differential. I want to check the fluid in it.
I took one of my 3/8 socket with a breaker and twisted the end off the extension. I guess the weak point is where the locking detent is in the extension because it split there.
Is there a special tool for this?
Nope, 3/8 extension like you used. Usually the problem is you screw up the plug if you don't clean it out first and get a shallow bite. You're the first I've ever heard of that had the extension break. Take a torch and heat around the plug for a minute or two and try it again.
futuredoc
Oct 7, 2024 06:14 PM
Drew4711
Oct 6, 2012 12:47 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
boulonman
Mar 5, 2007 05:10 AM
