replaced engine, no power to starter from ign!
Old Nov 7, 2014 | 10:39 AM
chevyriders's Avatar
Default replaced engine, no power to starter from ign!
I havent been on here in a while, but i hope someone can help me out. First ill say that i did search the site before posting this, i did all the diagnosis i found and this is what im left with.
I have a 2000 blazer. I just replaced a blown engine. when i went to start it up for the first time, the starter didnt turn over. heres what i know so far:
-main power to starter has 12v
-power wire from ignition reads 0v, even when key is turned to start
-All related fuses(ign, crank, etc) and relay are tested and GOOD
-starter is brand new, and has been bench tested
-all other electronics seem to be working(with exception of headlights), dash lights come on, fuel pump kicks on, locks work, etc
-when i jumped the starter solenoid with the key on, the engine turns over, i get spark, but engine still will not fire
any help would be greatly appreciated. thanks!
also, someone said maybe a neutral safety switch? but i didnt touch anything in that area and it worked fine before
Old Nov 7, 2014 | 08:00 PM
rexazz2's Avatar
GMs usually had a Fusable Link at the starter
One of the smaller wires that attach there
Old Nov 11, 2014 | 06:07 AM
i dont recall seing one there, but ill take a look into it. thanks for the idea
natem504
Apr 22, 2015 04:07 PM
jdmmario
Oct 25, 2014 06:25 PM
lilblazer
Aug 9, 2014 11:12 AM
blackhawk61
Jun 10, 2014 04:32 PM
Boiler_81
Oct 30, 2011 05:01 PM
