Replaced starter but there is a gap
Old Aug 8, 2014 | 10:38 AM
lilblazer's Avatar
lilblazer is on a distinguished road
Default Replaced starter but there is a gap
We installed a new starter, and there is about a 1/4" (or less)gap at the bottom of where it goes into the flywheel--is that right?? We didn't pay attention if the one we took out was like that. Won't water and such get in there?
Also, on another problem, Have white smoke with strong fuel odor, running rough. After searching this problem-I've checked the plugs-seem normal tannish color, not black or white. coolant level hasn't changed. Also oil seems thinner and a "bit" over full mark with ,i think, a fuel odor to it. Can gas get into your oil?
codes i'm getting/gotten lately are:1345--1133--134--144--152--133--102
Thanx for any insight.
Old Aug 8, 2014 | 09:08 PM
DTC's must be diagnosed & repaired in the order they are retrieved. The P1345 means the distributor is not installed correctly, (off at least one tooth). It must be corrected first, then clear the memories and perform a drive cycle.
Old Aug 9, 2014 | 08:04 AM
lilblazer's Avatar
thanx for the reply. were going to try to move the dist. looks to be off a little bit. How about the gap at the bottom of the starter--anybody know about that?
Old Aug 9, 2014 | 11:06 AM
odat's Avatar
I have a 97 LS 4.3 automatic there is a tin plate that bolts to the block to heip cover the gap
Old Aug 9, 2014 | 11:12 AM
akaSPITTYBAYS's Avatar
akaSPITTYBAYS is on a distinguished road
I have no gap on my 95 don't think you should have one. If your injectors or fuel pressure regulator (FPR) are leaking you can get gas in your oil. Pull the dip-stick and smell, it may smell like gas. Do a fuel pressure leak down test. Directions are all over the board.
chevyriders
Nov 11, 2014 06:07 AM
shotnva777
Sep 10, 2011 01:14 AM
fast eddy
Performance & Brainstorming
Aug 1, 2010 09:45 AM
mcaanda
May 23, 2009 04:04 PM
