Replaced Vacuum Lines - Now Rough Idle
Old Nov 8, 2010 | 04:32 PM
keego's Avatar
keego is on a distinguished road
Default Replaced Vacuum Lines - Now Rough Idle
I replaced 2 vacuum lines on my '99 blazer. I had to take the breather assembly off to get access to the rear of the manifold. I unplugged the MAF and another sensor just behind it. (what is that one anyway?) When I put it all back together and started it up, it seems to idle fine except every few seconds the rpm's drop for a second, like it's going to stall, then it goes back up to normal idle. It keeps doing this and even when I drive it, it seems hesitant to go from a stop. Anything?
Old Nov 9, 2010 | 04:21 PM
keego's Avatar
I just wanna bump this cause I really need help.
Old Nov 9, 2010 | 06:09 PM
Are you sure everything is connected back up properly? Have you double/triple checked everything you messed with?
The sensor behind the MAF is the IAT (intake air temp) sensor.
klote82
Apr 27, 2012 08:22 PM
jasonscottclack
May 25, 2011 07:03 AM
Electrode
Dec 13, 2010 12:51 PM
ohsofly
50
Feb 22, 2010 01:52 PM
greenclover19
Mar 26, 2008 03:13 PM
