Replacement Key FOB
#21
i've had similar issues, i ordered a set of 2 from remotesremtoes and both died within a few weeks, not battery wise but just up and quit. they sent me one replacement since i had reported one failing but not the second, the replacement also had the same issue. Repalced batteries in all with several different coincells that i know have power and they refuse to program. its a royal pain in the dick actually and im not sure if its just a function of my work (busy kitchen = smacking keys on things constantly) so i dont want to pay 65$ for a Delco Fob.
#22
Thanks for the insight. To tell you the truth I have no idea what to expect at this point. The seller on E-Bay is registered as 'yourkeyelessremote.com' not sure of anything else. There is a Delco option? I was not aware. Could you pm me details.
At this point it is hit and miss I am not expecting anything spectacular to happen. The delivery date for the button fob with the right part number is around Sept
Thanks for the info
regards
Thanks for the info
regards
#23
Thanks for the info
regards
Thanks for the info
regards
https://www.rockauto.com/en/moreinfo...430986&jsn=887
listed for an '05 Blazer but its the same P/N and remote throughout all makes.
#24
Thanks for the link. I do not think this will work. The part number does not match the one on the back of my FOB. I have been told that if the part numbers do not match then they will not work. I will keep it in the back of my mind for a last resort
Thank you again
Thank you again
#27
I have been informed that today is the day that the correct part number FOB should be arriving by Canada post.
Now, I have been thinking on what to do next if this new FOB does not work and apart from saying **** it and moving on like I should be doing. I had a thought. A few years ago I had to replace the ignition cylinder in the 98. I have started to wonder if when I turn the key off and on 3 time as per the instructions with the new cylinder maybe the system is not going into the program mode as it should and that is why I cannot get a new FOB to program.
Just wondering, Anyone have any thoughts?
Regards
Regards
#28
OK the replacement key FOB arrived in the mail today. Late but at least it arrived I had pretty much given up. Its the right OEM part # and the FCC # on the case match the original.
Instructions printed and I am ready to go. Will see what happens. If this does not work I suspect its the new lock cylinder that is the problem
Regards
Regards
