Replacement shocks
Old Jul 31, 2016 | 11:04 AM
GeorgeLG's Avatar
Default Replacement shocks
I liked my OEM shocks but alas, after 200,000 miles, they are worn out. Whats the closest aftermarket brand and model?
Thanks,
George
Old Aug 3, 2016 | 09:26 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
Here is a source to let you see options and get you going Chevy Blazer Performance Suspension | Springs, Shocks, Struts
Old Aug 4, 2016 | 09:53 AM
Racer_X's Avatar
Racer_X is on a distinguished road
Figure out what you have first. Look at the sticker in the glove box, the "SPIDS," which has the RPO codes for everything in your Blazer. The suspension related codes will tell you which springs and shocks you had from the factory.
ZR2 is the "Higher wider" package, and you probably don't have that. The shocks and suspension parts for that are all unique to that package. If you have that, you need shocks that match that RPO code/package.
Z85 is the "Extended load" or heavy duty suspension. It's usually coupled with Z82 and was sold as the "Tow package" or "trailering package."
ZW7 is the "Smooth ride chassis" package" with softer springs and matching softer shocks.
AC-Delco has several different shocks to match OE specs based on your specific suspension.
In the aftermarket (other than AC-Delco), I've always had good luck with Monroe shocks, and in recent years, I've run some Gabriel "Ultra Truck" shocks with good results on some of the "truck-ish" vehicles I've owned or maintained for friends/customers (Ford Exploder, Chrysler Minivan, Jeep Cherokee).
All of these are available online from Amazon vendors, or from rockauto.com, and are priced fairly competitively.
Old Aug 4, 2016 | 12:59 PM
Blazer2809's Avatar
Blazer2809 is on a distinguished road
I have Monroe reflex shocks on my truck with the monotube...I like em...I bought them off rockauto
Old Aug 4, 2016 | 08:13 PM
GeorgeLG's Avatar
I have the Z85 package. Does anyone know which aftermarket shocks equate to these?
Thanks,
George
Old Aug 4, 2016 | 10:25 PM
Racer_X's Avatar
For the 4 door LS in 2002, with the Z85 chassis package,
4WD Front AC-Delco 540-41
4WD Rear AC-Delco 540-43
Those are exact OE replacements from AC-Delco.
Monroe 37099 (front) and 37021 (rear) will fit. Monroe lists those for all LS models, regardless of chassis package. The Monroe "Reflex" that were mentioned are a slightly stiffer, "performance" version. For yours, the Reflex part numbers are 911099 (front, 4WD) and 911021 (rear).
bigdaddykane93
14
May 8, 2014 08:54 AM
ssean92
Lowering Tech
Oct 28, 2013 12:14 PM
skybum02
17
Aug 31, 2011 02:02 PM
doublearon
Lifting Tech
Jun 26, 2009 08:29 AM
jagblazer01
Apr 16, 2009 03:54 PM
