replacing brake lines?
Old Feb 19, 2012 | 10:03 PM
rocket9244's Avatar
rocket9244 is on a distinguished road
Default replacing brake lines?
can I cut the bad part off and add a new piece to the line?
what is covering the line? do I have to cut past the "spring" looking cover on the line, or will that slip off after I cut the line?
Old Feb 20, 2012 | 12:28 AM
NVANZEE's Avatar
yes, you can cut out the bad section and get a couple compression fittings and a new section of line. You will probably have to go past the protective coil around the line. I doubt it will slide off but you can try.
Old Feb 20, 2012 | 11:49 AM
chcknugget's Avatar
chcknugget is on a distinguished road
That spring stuff will slip off after you cut the line- as long as it isn't rusted solid to the line...
Old Feb 20, 2012 | 04:25 PM
rocket9244's Avatar
Default line is fixed but now it wont start lol. turns over and everything but not start. Dam
Old Feb 20, 2012 | 04:36 PM
xgiovannix12's Avatar
new lines looking good
do you hear the fuel pump when ya turn the key on?
Old Feb 21, 2012 | 08:29 AM
chcknugget's Avatar
Also, it looks like you have to replace the other lines in that spot- two of them are the evap lines that run to the charcoal canister... I replaced them with 1/4" fuel line.
Old Feb 21, 2012 | 11:31 AM
rocket9244's Avatar
Default It started but is running rough
it finally started, maybe I flooded it IDK. it needs a major tune up for sure but it is having trouble at idle.
and the oil gauge goes up/down like the rpm does/at the same time. that make any sense ?
I'll look and see if maybe I knocked a vacuum line loose or something last night while doing the brake line.
how do you change the spark plugs? they look like they will be a pain to get to.
Old Feb 21, 2012 | 11:44 AM
Tony H's Avatar
Tony H is an unknown quantity at this point
turn the key to the ON position listen for the short fuel pump sound to stop.... do this a few times so the Fuel that siphoned down during the fix can get back up there where it belongs. in other words, 'Repressurize the system'.
I'm glad you went with Flared fittings that's the correct way to do it .
Old Feb 21, 2012 | 11:46 AM
rocket9244's Avatar
it was the first time I've done a brake like, wasn't as scary as I thought it would be (thank you Youtube)
Old Feb 21, 2012 | 05:33 PM
Thank you giovanni ! haha playing with ya
any ways the spark plugs are easy
just make sure you got a swivel extension and your set
Patrick_Boyle
Dec 14, 2010 09:06 AM
lynnmcd
May 16, 2009 07:50 PM
rdhack
Jan 3, 2009 11:54 PM
primo
Jul 19, 2007 06:50 PM
