Replacing oil cooler lines
Old May 15, 2009 | 08:43 PM
lynnmcd's Avatar
lynnmcd is an unknown quantity at this point
Default Replacing oil cooler lines
I have 1999 bravada that has had an engine replacement 3 years ago. I tried to get to the bolt that holds the cooler line to the oil pan and I cannot figure out how people that have repaired these have done it. Do some parts need to be removed? I was thinking maybe the diffficulty is due to the new engine.Any suggestions?
Old May 16, 2009 | 07:50 PM
Been covered in the past. Use a few long extensions and a swivel socket on the end. It is a 10mm bolt. It is possible to get it disconnected. The trick is getting the lines out of there once you get the bolt out. Sometimes they come right out. Sometimes you have to jack the motor slightly. And in extreme cases you have to disconnect the motor mount and jack the motor.
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
Patrick_Boyle
Dec 14, 2010 09:06 AM
Jetfixer
Jul 11, 2006 05:02 AM
zero psi
Oct 28, 2005 04:45 PM
