Replacing door hinge pins, and tips suggestions?
Old Feb 14, 2011 | 08:24 PM
n0thing43's Avatar
n0thing43 is an unknown quantity at this point
Default Replacing door hinge pins, and tips suggestions?
Im replacing the door pins in my 03 blazer this weekend. I bought the GM spring tool from Harbor Frieight, got the pins from Rock auto parts. Since this seems to be a common fix for Blazers, I wondering if anyone had any tips or suggestions for me before I attempt this fix? Anything will be appreciated!
Thanks
Chuck
Old Feb 14, 2011 | 08:45 PM
1hugeblazer's Avatar
1hugeblazer is on a distinguished road
should be pretty easy as long as the holes aren't messed up on the hinge.. i did mine last year, hopefully you have someone helping you.. if not you should make a jig that fits into a floor jack so it holds your door for you. even with someone helping you use a 2x4 and a floor jack under the door and your friend to balance the door while you put the pins in. it is fairly easy i did mine without the spring tool and that was a bastard!!
Old Feb 14, 2011 | 08:54 PM
01blaze2door's Avatar
01blaze2door is on a distinguished road
I put a top pin in mine awhile ago I would also suggest 2 people, me and my dad did mine. dont know about your truck but we had to weld up the hole a little and redrill it for my top pin cause the hole was worn into an oval shape... so good luck and get some extra hands.
Old Feb 14, 2011 | 09:56 PM
ABN31B's Avatar
OMG have a pal
do the top than the bottom (doesnt matter really) BUT replace it as soon as you can, THEN move to the next replacement!
get a door spring tool from something like harbor freight BEFORE starting the project.
seriously, have a dedicated friend on hand to support.... WAY better than straps, a wheelbarrow, or jacking up a chunk of wood!
also, even if the holes are in good shape, I would suggest doing the JB weld hole fill anyway. can't hurt to make them tighter
Old Feb 14, 2011 | 10:05 PM
Originally Posted by ABN31B
OMG have a pal
WTF wheelbarrow ?? and there is a proper jig that is like a motor picker with straps.. they use them in body shops, i used a floor jack and 2x4 because i didn't have a handy "pal"
Old Feb 14, 2011 | 10:11 PM
here is a couple
Old Feb 14, 2011 | 10:18 PM
ABN31B's Avatar
not knocking the 2x4. i used a wheelbarrow and a blanket to get my replacement door out of the JY. used a jack and 2x4 with 2x4 kickstand to prep for painting.
simply giving the advice I wish i had had befor ei took a stab at this as per the OP request
Old Feb 14, 2011 | 10:26 PM
lol ok i see i thought you were sayin im a knuckle dragging hick or something ha ha ha
Old Feb 14, 2011 | 10:34 PM
ABN31B's Avatar
dude, with a truck like yours, i would assume anything but
Old Feb 14, 2011 | 10:39 PM
lol thanks bro
