replacing fan belt?
Old Jan 11, 2007 | 10:16 PM
davtak's Avatar
Default replacing fan belt?
is it easy to replace a fan belt? Is it something I could do on my own? If it is, how?
Old Jan 11, 2007 | 10:36 PM
Default RE: replacing fan belt?
Yes, quite easy. First, make sure you have a belt routing schematic under the hood somewhere. If not, then get out a pad and pen and draw it. Then just relieve the belt tension by moving the spring tensioner with either a wrench or a breaker bar and pull out the old belt. Fish in the new belt and again, move the tensioner to get the belt under it.
Old Jan 11, 2007 | 10:44 PM
davtak's Avatar
I've seen that sticker when I last looked. Sounds easy enough. I like to try to save myself the labor charges with anything I can do myself. Thanks bro.
Old Jan 11, 2007 | 10:45 PM
No problem. Any questions or if you run into trouble, let us know!
Old Jan 12, 2007 | 12:35 AM
rooster's Avatar
rooster is an unknown quantity at this point
that tensioner can be a real pain in the ***, so use a heavy 1/2 inch racthet or breaker bar and be carefull!
Old Jan 12, 2007 | 05:03 AM
Chevy Lover's Avatar
While you have the belt off, grab hole of the tensioner and check for any wear in it (front to rear). If it's worn this is the perfect time toreplace it.
Old Jan 12, 2007 | 11:29 AM
rooster's Avatar
tell em about the spring chevylover, very dangerous
Old Jan 12, 2007 | 11:34 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
The springs are not much different then the ones in a Cadi
They do the same when the casing breaks, Duck and pray.
cferry7
Oct 25, 2013 04:22 PM
lionel2
Sep 7, 2012 02:45 PM
Bonedaddy
Jul 3, 2012 07:22 PM
k0rupt_ed
May 23, 2007 10:18 AM
