replacing the fan shroud in a 99 blazer
Old 07-13-2009, 11:58 AM
spampy's Avatar
spampy is on a distinguished road
Default replacing the fan shroud in a 99 blazer
So ours broke. And we bought a new one, upper and lower. And removed the old one, which was easy because it was broke. Is there some trick besides removing major organs to getting the lower back in?
Old 07-13-2009, 12:48 PM
bandidolenny's Avatar
If you remove the fan you will have a much easier time doing this... it's pretty easy to remove.
Old 07-13-2009, 12:50 PM
dew88's Avatar
dew88 is an unknown quantity at this point
Where can I get a fan shroud at?
Old 07-13-2009, 12:58 PM
Possibly most auto parts stores may be able to order you one. I would try your local salvage yards or you can order a new one through LMC Truck. Here's a link...
http://www.lmctruck.com/icatalog/cst/full.aspx?Page=131
Old 07-13-2009, 01:00 PM
dew88's Avatar
Thanks
Old 07-13-2009, 01:09 PM
spampy's Avatar
easy as in anybody can do it? How does one remove the fan?
I got our off of ebay.
Old 07-13-2009, 07:14 PM
Depends on the year of your truck but either way, it's not rocket science. Just take a look at it... if you have the type that the fan clutch spins off, the large nut turns counter clockwise to loosen it.
Old 07-13-2009, 08:11 PM
bluefulltop1975's Avatar
bluefulltop1975 is on a distinguished road
mine is just held on with 4 bolts. should come right off after that
Old 07-13-2009, 10:19 PM
Huge difference between a fullsize and the 2nd gen s-series...
I had to replace the lower shroud after I hit a dog with my old 2000 Bravada. I just pulled the fan/clutch assembly out and installed it all from the top. It was fairly easy. The bottom shroud has tabs that fit into slots in the radiator tray on the core support. Once you have that installed, reinstall the fan and then the upper shroud.
Old 09-27-2009, 08:54 PM
Surferdude is on a distinguished road
be careful with the radiator, i cracked mine doing this :[
Quick Reply: replacing the fan shroud in a 99 blazer
