Replacing MFI spider, FPR, and manifold gaskets
Old Jul 3, 2010 | 05:39 PM
Patrick_Boyle's Avatar
Patrick_Boyle is an unknown quantity at this point
Default Replacing MFI spider, FPR, and manifold gaskets
I'm getting ready to service our 2001. It's been progressively getting harder and harder to start due to a leaking FPR. I'm going to upgrade it to MFI in the process with p/n19210688. I'm also leaking coolant down the side of the block towards the tranny. I've got the Fel-Pro intake manifold gaskets to hopefully cure that problem. So the throttle body and lower intake plenum are coming off. I'm also doing plugs, cap, rotor, fan clutch, motor mounts, and replacing vacuum lines.
Is there anything else I should be thinking of. Anything to look out for when taking off the plenum?
Old Jul 8, 2010 | 09:38 PM
rdlyn's Avatar
rdlyn is on a distinguished road
You may have seen this before, but it's a pretty good write-up. Probably has more than you need, but still...
let me know how the mfi swap works out. I'll be doing that myself next week.
http://www.handymanlyness.com/archiv..._99_Jimmy.html
Old Jul 9, 2010 | 12:30 PM
rdlyn's Avatar
...and for the spider:
http://www.automotiveforums.com/vbul...d.php?t=559014
apologies in advance for posting links to outside the forum.
good luck!
koreiryuu
Aug 26, 2014 10:09 PM
gsaum
Apr 9, 2013 11:37 AM
shanegreen
Apr 30, 2012 02:38 PM
kc0alg
Jul 16, 2011 09:41 PM
greg94
Nov 17, 2010 09:15 AM
