Replacing Radiator - difference between AT and MT?
Got a crack in the drivers side plastic end tank on the radiator so i'm just planning on replacing it, is there a difference between the auto trans and manual trans rads?
I only ask because most of the ones i see specify for automatic transmission or manual transmission. I'm suspecting it may have more to do with mounting but not sure.
Just looking for cheap replacement, i don't need an all aluminum one since i only use my blazer to haul trailers a handfull of times during the year.
This is the one i'm looking at but i have a 5 speed so wasn't sure.
http://cgi.ebay.com/ebaymotors/96-97...ht_4013wt_1165
I also planned on replacing all the tubes since I was going to be in there already, anything else that i should replace since im going to be in there?
Thanks guys.
Thanks guys.
So if I am understanding this right, you can use one made for an auto on a manual, but you cannot use one made for a manual on an auto?
It seems a lost of listings either say Automatic Transmission or Fits Both
Yeah the 97's definitely have the engine oil cooler built into the radiator.
I lost an engine out of my previous '97 i had back in college because when i had the rad replaced on that one the shop didn't replace the clip on the oil cooler and it blew the engine
seeing as i actually know what im going now under the hood i prefer to save the money and do it right this time, lol
fbkronos73
Dec 28, 2009 02:25 PM
Pugsley
Feb 2, 2006 10:08 AM
