Replacing Spark Plugs Help!!
Old Oct 31, 2005 | 06:38 PM
yzf125's Avatar
yzf125 is an unknown quantity at this point
Default Replacing Spark Plugs Help!!
Hey guys , I have a problem [:@] I dont see any way to remove the middle spark plug on the drivers side ????? The steering wheel shaft is in the way, Anyone know how to remove this plug ??? PLZ HELP !!
Old Oct 31, 2005 | 08:42 PM
yzf125's Avatar
Default RE: Replacing Spark Plugs Help!!
Nobody has ever replaced there sparkplugs ????? By the way its a 2002 blazer
Old Oct 31, 2005 | 09:59 PM
drkmelvin's Avatar
drkmelvin is an unknown quantity at this point
sorry, I have a chevy v-8 in mine... I use a boxwrench, and a tool I got from Autozone... it is a spark plug socket with a swivel and a t-handle attached to it
Old Oct 31, 2005 | 10:01 PM
drkmelvin's Avatar
This is how tight mine is
[IMG]local://upfiles/1246/A9F62CFD38AA441BA3F688CBA612C193.jpg[/IMG]
[IMG]local://upfiles/1246/0F660B3B16E243F58D527D40C538221D.jpg[/IMG]
Old Oct 31, 2005 | 11:38 PM
irocbadboy's Avatar
irocbadboy is an unknown quantity at this point
hi,remove the wheel on the left side and change the plug (i have changed my plug with no problem with this method)
Old Oct 31, 2005 | 11:52 PM
yzf125's Avatar
I had the wheel off , Thats how i did the others, The steering shaft goes right across the center plug on mine. i dont see how you could do it without removing the shaft ??? Thanks for any help.
Old Nov 1, 2005 | 01:42 AM
nslide10's Avatar
nslide10 is an unknown quantity at this point
remove motor mount on that side, loosen cross member bolts and jack engine up an inch or 2 than u can get at it
Old Nov 1, 2005 | 02:31 AM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
if thats the only way to get it i would sell the truck...lol theres got to be a better way i havent tried to change mine yet so i dont know
Old Nov 1, 2005 | 03:18 AM
drkmelvin's Avatar
The spark plug socket has a hex end on it... put the socket on the plug, and use a box wrench to turn it off... it's not that difficult.
Old Nov 1, 2005 | 09:33 AM
yzf125's Avatar
There is so little room i could bearly get the socket on, just about forced it . and i couldnt get a box end wrench onto the socket, theres just no room with that heat shield on the manifold. But even if i could ,when i start to losen the plug it would be stuck against the steering shaft with 2 or 3 turns ??? Thats how close it is..
