Replacing Spark Plugs Help!!
Old Nov 1, 2005 | 10:13 AM
Default RE: Replacing Spark Plugs Help!!
I was able to get mine without too much difficulty on my 2k Bravada... I used a regular socket (that's shorter than a spark plug socket) and my wobble extensions (15* of wobble) to get that plug out. Many other places have said that if you remove the plastic sheilding around the steering shaft, that the shaft itself has a flat on it that will free up the room required to remove the plug.
Old Nov 2, 2005 | 11:22 AM
93LT's Avatar
93LT is an unknown quantity at this point
Like the previous poster, I used a socket (I just used the regular spark plug socket, but that little rubber gripper can make it a pain to get off the plug once installed), stuck it on the plug, then a swivel, then an extension out through the wheel housing.
Old Nov 3, 2005 | 12:55 AM
blazin97's Avatar
blazin97 is on a distinguished road
It is really easy, Remove your driverside wheel, then turn your steering wheel a littile(till the flat peice is on top, put the socket on the plug, use about a ft extention and wratchet.
JavierEscalonJr
Oct 14, 2020 11:38 PM
blazzer
Jun 4, 2013 04:40 PM
abe_f
Apr 1, 2013 11:19 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
lowe42
Sep 8, 2006 04:50 AM
