Replacing the water pump so how to i take off the fan and fan clutch off of the water
Old Sep 21, 2016 | 03:25 AM
TheSaint's Avatar
TheSaint will become famous soon enough
Default Replacing the water pump so how to i take off the fan and fan clutch off of the water
The water pump on my car is worn out so i have to replace it
I see that the axle on the water waterpump have threads
I wonder how do i take the fan and fan clutch off of the axle on the water pump?
Any knows if the threads on the water pump axle loosen the clockwise or if the threads loosen counter clockwise?
Attached Thumbnails Replacing the water pump so how to i take off the fan and fan clutch off of the water-bilde-2.-vannpumpe.jpg
Old Sep 21, 2016 | 11:50 AM
Raybz's Avatar
Raybz is on a distinguished road
Either put a chain wrench on the pulley to hold everything still
OR
Put a big a$$ adjustable wrench on the nut for the fan nut....kinda throw it one way then smack it the other way with a BFH
Chain wrench is the preferred method LOL
ETA: I want to say counterclockwise to remove?
Old Sep 21, 2016 | 12:06 PM
chris015's Avatar
its counterclockwise
1. Use a pipe wrench.
2. leave belt on pump to help with slipping.
3. lay a blanket under wrench to protect stuff. hit pipe wrench with hammer.
4. drink a beer.
Old Sep 21, 2016 | 07:36 PM
awesomeamerican1's Avatar
awesomeamerican1 is on a distinguished road
I always used a long a$$ screwdriver/pry bar to wedge in between two of the screws on the pulley for the pump and then i think a 24" crescent wrench to get that junk off. While you're at it, go find yourself a 00+ dodge intrepid electric fan to replace that junk LOL
Also I agree with drinking beers after any mechanical work!
Old Sep 21, 2016 | 07:50 PM
rexmburns's Avatar
Super Moderator
I use this
Attached Thumbnails Replacing the water pump so how to i take off the fan and fan clutch off of the water-79c58f14-3aee-434c-8f43-c350df21eca8_zps1zxa3as8.jpg
Old Sep 21, 2016 | 11:08 PM
Markolc's Avatar
Markolc is on a distinguished road
I've done it two ways:
1. a strap wrench to hold the pulley, and a large adjustable wrench on the nut, turn counter clockwise and it'll budge, sometimes gotta hit the wrench with a hammer for a bit of an impact.
2. Rexmburns's method - air hammer with a chisel, I put the chisel right on the edge of the nut, one quick blast and the fan is coming right off :-D This is my favorite way.
Old Sep 22, 2016 | 12:32 AM
rexmburns's Avatar
Super Moderator
No chisel in my method it's a tool specifically designed to remove fan clutches using an air hammer that takes about 3 seconds of pulling the trigger and then finish removing with your fingers!
Old Sep 22, 2016 | 09:19 AM
jimspahr@msn.com's Avatar
If you didn't have a 24" crescent wrench, what is the actual size of the nut. Is it 36"?
bruuce
28
Oct 23, 2011 09:31 PM
MintyMadness
Jul 13, 2011 12:37 AM
Fusefinder
Jun 29, 2010 09:20 PM
bornla
Nov 28, 2009 11:55 AM
2klt
Apr 2, 2006 11:37 PM
