reuse the axle nut?
Old Oct 20, 2009 | 01:39 PM
waterlogged's Avatar
waterlogged is on a distinguished road
Default reuse the axle nut?
Hello I need to replace the front wheel bearing hub assy on my 2000 4x4 Blazer. My question is; can I reuse the the axle nut? Or, do I need to replace that also? I'm having a hard time getting it loose. Also should I put antiseize on the splines? Thank you for any input.
Old Oct 20, 2009 | 03:16 PM
Yes you can reuse the nut. That is unless you damage it and then you should replace it.
As far as the use of antiseize goes, it is a mixed bag of answers. With any lubricant, you will be able to more accurately torque the fastener. But lubricant also can aid in the joint coming loose. Personally, I would not use it.
myblackblazer
Mar 22, 2011 04:41 PM
TheCackster
Nov 22, 2009 11:24 AM
Bojib
Mar 30, 2008 11:41 AM
frankjc
Suspension Tech
Sep 10, 2006 04:56 PM
98Blazer
Feb 15, 2006 05:40 PM
