rocker bolts
Old Jul 18, 2009 | 03:31 PM
theflyingtomato's Avatar
theflyingtomato is on a distinguished road
Default rocker bolts
just put my motor together and was wondering what the rocker bolts have to be torqued down to?
Old Jul 18, 2009 | 04:38 PM
cc4usa's Avatar
cc4usa is on a distinguished road
that depends on if the rocker studs are pressed in or screwed in 4.3L V6
screwed in studs 1994-1996 20 ft lbs. 1997-1999 18 ft lbs
pressed in studs you will need to adjust the valve lash as if you were working on a 350 v8
Old Jul 18, 2009 | 05:07 PM
ok i have pressed in studs but they have a flange bolts and i heard that the flange bolts are the ones that have to be torqued down and the other ones are adjusted like a regular v8
Old Jul 18, 2009 | 05:28 PM
cc4usa's Avatar
what year type and vin code is your engine ?
Old Jul 18, 2009 | 05:45 PM
W and 95
Old Jul 18, 2009 | 05:47 PM
and another thing is that one side has 5/8 studs and the other ones have 3/8
Old Jul 18, 2009 | 05:59 PM
cc4usa's Avatar
sounds like you have 2 different heads or one has been drilled out but i stand by my info
if the studs are pressed in. adjust them for lash as you would a 350 v8. for reference pick up a Chilton manual on s series pickups.
Old Jul 18, 2009 | 09:00 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
1995 vin w 20 ft lbs
Old Jul 19, 2009 | 01:50 PM
appreciate it guys
ESKYMOPACK
22
Dec 24, 2010 11:47 PM
Spectreblazer
Jan 18, 2010 10:19 AM
magnum434
Sep 21, 2009 10:47 AM
stevelknievel
Sep 19, 2007 08:54 AM
Cow Killer
Jul 5, 2006 02:25 PM
