rockerarm adjustment
Old Dec 22, 2012 | 08:14 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Smile rockerarm adjustment
case closed thanks to google
Old Dec 22, 2012 | 09:37 PM
If you still need the info, here it is:
Align the crankshaft as pictured below.
Then rotate the crankshaft clockwise 57 to 63 degrees.
Torque the rocker arm nuts to 18 foot pounds.
Old Dec 23, 2012 | 09:40 AM
Question
Thanks alot Captain Hook I did need this info.Question why is there 2 timing marks on the balancer?
Old Dec 23, 2012 | 10:43 AM
Twip's Avatar
one is TDC (top dead center) and the other is xx degrees ATDC (after top dead center)
i put in xx because im not sure how many degrees it is.
Old Dec 25, 2012 | 04:57 PM
When the marks are lined up as they are in the image above, the mark at the 2:00 position indicates #1 piston is at TDC, (Top Dead Center).** The mark at the 4:00 position is 90 degrees BTDC, (Before Top Dead Center) for #1 cylinder.
On a V6 engine, one cylinder fires every 120 degrees of crankshaft rotation. Not sure why they put 2 marks on it
**Depending on the position of the camshaft, it could be the end of the compression stroke, or the end of the exhaust stroke.
Old Dec 25, 2012 | 09:16 PM
Well I didnt notice if my balancer has the 2 marks on it or not.Guess Im going to have to check.
Old Dec 25, 2012 | 09:24 PM
If the distributor is off one or more teeth when the engine is running, DTC P1345 will set in memory and if the check engine light works, it will come on. If it is meshed correctly, camshaft retard is within ~27 degrees, (desired spec is zero degrees with a tolerance of + or - 2 degrees).
kaejr
May 22, 2007 01:01 PM
drperry
May 3, 2007 07:50 PM
Chevyguy032
Apr 6, 2007 05:15 AM
rlt7272
Suspension Tech
Mar 9, 2007 02:20 AM
chevy_kalle
Oct 22, 2006 09:17 PM
