rod knock sensor ?
Old Jan 28, 2011 | 01:57 PM
1997 tricky1's Avatar
1997 tricky1 is on a distinguished road
Default rod knock sensor ?
hello all,i have a 1997 4.3 i just picked up and did a intake gasket and flush but it messed up a rod bearing i was wondering since the rod knock has occured it now runs like the motor is retarded,is it possible to cut the wire to the knock sensor and it will run better but still have the rod knock.i was told the knock sensor retards your timing .thanx to all for reading and your responses
Old Jan 28, 2011 | 05:37 PM
step66's Avatar
UH-no First off:the knock sensor will not silence bearing noise! The knock sensor is to control timing under various load situations. You gave no mileage or other info,but I suspect the distributor is off as well... The rod knock was probably already there.
Old Jan 29, 2011 | 10:58 AM
i under stand it wont silence the noise.i asked if cutting the knock sensor wire will put the truck back in time.it has 142000 miles the distributor is in the right timing i know because it ran fine for two days then started knocking worse and then runs like its out of timing,thats why im asking if i cut the knock sensor wire does it put the truck back in timing where it will run better even with the knock!
Old Jan 29, 2011 | 02:04 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
All I can say is I doubt it. I don't know exactly how a GM one works but I know in a general sense the knock sensor is tuned to a specific frequency. If I remember correctly pre-ignition is around an 8khz vibration. I would think a rod knock is in a lower frequency. If you had a scanner with operating data it'd be interesting to know the timing retard.
Old Jan 30, 2011 | 01:15 AM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
When you changed your intake gaskets did you clean up the gasket surface with a flap disc? If yes they are known to leave very small pieces of gritty crap in your engine that can wreck rod bearings in 50 miles or less. If you take your engine apart I`ll bet you have one or more orange looking bearings.
Old Jan 30, 2011 | 01:29 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Personally I think you ought tto fix the rod knock first then takle the diveability issue.
Old Jan 30, 2011 | 08:16 AM
thanx all for the replies,i think ill fix the rod knock by putting a v-8 in it.i wonder what motor will work the easiest in this 1997 4x4 142000 mile 4.3 vortec blazer.im on my way to the search engine to find out,thanx all
Old Jan 30, 2011 | 01:09 PM
There's a lot of info on the V-8 swap out there as well as parts to do it.
Klturi421
Aug 2, 2011 07:21 PM
georgia_boy79
Mar 2, 2011 01:10 PM
RandyRhoadsFan82
Oct 4, 2010 10:44 PM
ejschultz
Sep 25, 2009 04:05 PM
Tony H
Jul 17, 2009 08:16 AM
