rollover vent valve
Old Jul 26, 2013 | 04:28 PM
newguy's Avatar
Default rollover vent valve
Where does the hose go to?
Old Jul 27, 2013 | 01:25 PM
xillzxnickx's Avatar
xillzxnickx is an unknown quantity at this point
What state your question better
Old Jul 27, 2013 | 01:44 PM
newguy's Avatar
Hose coming off rollover vent valve on top of gas tank, what does it connect to?
Old Jul 28, 2013 | 02:18 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
I'm not entirely sure what you're referring to. Here's what I can remember from my recent work on the fuel and emissions systems of my Jimmy:
The filler neck goes from the gas cap down to the tank. There's a check ball in the end of the neck just before the tank. That ball is supposed to prevent fuel leakage in the event of a rollover. It's also an impediment to those who would siphon gasoline from the tank.
There's a vent line that goes from the tank up to the filler neck just before the gas cap. That's about a 3/4" rubber hose. There are small (+/- 1/4") rubber lines coming from fittings on the top of the gas tank. Those go to the charcoal canister in the left rear fender behind the wheel. There's a similar small line that goes from that canister to the purge valve on the engine. Also on the charcoal canister is about a 3/4" rubber hose that goes to the canister vent solenoid mounted above the spare tire on the frame.
Hopefully some of that will be helpful to you.
Old Jul 28, 2013 | 04:22 AM
newguy's Avatar
yep 1/4 inch hose going to charcoal tank ,thanks
ve3nsv
Mar 23, 2012 04:45 PM
abig84
Nov 17, 2011 06:55 AM
2002XTREME
Oct 26, 2009 06:25 PM
scottmac
Sep 29, 2008 08:59 PM
Havsurf
May 22, 2008 07:32 PM
