roof rack question
Old Mar 20, 2005 | 08:01 PM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
Default roof rack question
alright, so i just took off the roof rack on the blazer and realized that there are the screw holes in the roof... will these leak through to the inside i couldnt really see... if so has anyone taken theres off and what did they do to solve the problem...right now i have tape covering the holes lol let me know thanx
Timey
Old Mar 20, 2005 | 10:37 PM
V6 Vortec Jimmy's Avatar
V6 Vortec Jimmy is an unknown quantity at this point
Default RE: roof rack question
yes they will leake i took my rack off I covered it up with body filler or somethen like that me and my dad put on their.I think he welded it or somethen dont remember.
Old Mar 21, 2005 | 12:40 AM
can you find out if he welded it...if so how bc my dad welds too thanx
Old Mar 21, 2005 | 01:04 PM
Patrick's Avatar
Patrick has disabled reputation
you could weld them up, which would be the best way if you know a very good welder..but then youd ahve to paint the truck...also, i would strongly recommend pulling the headliner or any other flammable material away from the roof when welding.it will get veryhot and melt/burn the cloth..
Old Mar 21, 2005 | 07:24 PM
My dad just filled it up. Welding can be done also but i just covere my holes up with filler.
Old Mar 21, 2005 | 09:02 PM
Patrick's Avatar
with the newest craze for the import racers of removing factory wings...some shops that sells import stuff sell "hole plugs"..they are very very cheap, and are easily painted to match the body color...they simply pop into place...and if you ever want to re-install your rack, they can be popped back out. i have included a picture of trhe plugs in a trunk lid....
[IMG]local://upfiles/526/6BE73623513C42109E36BA0CF7D6C305.jpg[/IMG]
Old Mar 21, 2005 | 10:35 PM
hmm... that could be a thought i bought body filler today so i think im gunna go that route
Old Mar 22, 2005 | 08:32 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
you really should weld the holes up. the body filler will just crack. and filler isn't waterproof...it absorbs moisture so it will suck it in throught the crack and cause a leak and/or rust. just dont get the metal too hot when you weld them, or your roof will be warped as f**k[sm=massbounce.gif]
Old Mar 22, 2005 | 06:34 PM
Patrick's Avatar
you dont like my plug idea either zero?
Old Mar 22, 2005 | 11:35 PM
zero psi's Avatar
Retired Admin
i guess its a quick way out, but im a picky *****. nothing personal, but i worked at a body shop for a few years and went to school to build street rods and kustoms so its been drilled into me to do it so it looks mint. but ifyou dont have access to the right equipment, then it'll work
