Rough idle and a flashing Service engine soon light
Old Sep 24, 2025 | 05:33 PM
JByrd's Avatar
JByrd is on a distinguished road
Angry Rough idle and a flashing Service engine soon light
My 2000 blazer has recently had a new issue with the Service Engine Soon light flashing, and the idle is really erratic, with it wanting to die. I put new plugs, wires, cap, rotor, and coil. A scanner coding the MAF and random misfires. Replaced the MAF and still running really rough. Put a scanner on it again and got codes on the crankshaft position sensor and throttle position sensor. I replaced them and still running rough, wanting to die. I don't know what else to check. Can anyone help with some suggestions?
Old Sep 24, 2025 | 07:36 PM
puttster's Avatar
if there is a slight rattling sound somewhere and it feels like power is running 50% and you get a P0420 and MAF code .. well, when that happened to me I got a new catalytic converter and all was well. I did not have a flashing SES, though.
Old Sep 27, 2025 | 12:59 AM
GeorgeLG's Avatar
Check the stability of the reference voltages at a few sensors.
An exhaust restriction would cause a significant loss of power at full throttle.
George
Old Nov 9, 2025 | 07:29 AM
LannyL81's Avatar
Changing the crankshaft position sensor requires performing a crankshaft position re-learn be done. This requires a scan tool capable of putting the PCM into the correct mode. Plenty of threads here that gives all the details.
Also be sure to check the camshaft retard setting.
mjink.11
Jan 2, 2013 11:10 AM
quick711
Feb 20, 2012 05:30 PM
Mitchman38501
Jun 16, 2011 01:00 PM
LAWDOG
Mar 5, 2010 04:51 PM
gizwilly
Jun 11, 2007 02:44 PM
