rubber mounts on bottom of engine and transmissions- oil leak
the two plugs in question are removed to gain axcess to the very rear oil pan studs and nuts inside the bell housing, they can be a real pain to get back in while trans is attached to engine - oil above starter could be from intake gasket - valve cover gasket - oil pan gasket or even a leak in the oil pressure sender - iv'e even had the gasket under the dist shaft leak and trickle down there
No oil coming at all around distributor, couldn't find a crack on the valve cover. Although its hard to see in some places, I looked mainly where it is bolted on especially towards the back, and felt around and couldn't find any cracks.
Cassera
13
01-16-2011 03:30 PM
rhaig
11-22-2009 07:28 PM
chris015
04-28-2009 11:29 PM
