Rubber Oil Lines
Old Mar 30, 2006 | 02:38 PM
bigbrett's Avatar
bigbrett is an unknown quantity at this point
Default RE: Rubber Oil Lines
My mechanic said you could get some adapter for a Camaro or something, and screw the filter right on to the motor. Elliminating the external system all together. Have you guys heard of this? Would there possibly be a problem elliminating the cooler, or maybe clearance to change the filter?
Old Mar 30, 2006 | 05:04 PM
kaindragoon36's Avatar
kaindragoon36 is an unknown quantity at this point
ORIGINAL: Jman
Are you replacing the lines from filter to cooler? or filter to motor?
If you are replacing the lines from filter to motor than there is enough hard line coming out of the filter.
Jman,
I'm replacing motor to filter lines. But the actual hydraulic shop said the hard lines coming out of the filter were too close to the bend to put the fittings onto. (I'm gettin some heavy duty $18 bucks a piece fittings) That's the only issue.
Old Mar 30, 2006 | 05:51 PM
ORIGINAL: bigbrett
Well, I figure they install an oil cooler for a reason...to cool the oil! cuz it does get too hot. I wouldn't do it.
Old Mar 30, 2006 | 06:17 PM
bigbrett's Avatar
That's what I was thinking too. I'm going with the hydraulic setup you guys talk about here personally. I've already replaced mine with dealer parts once about a year ago, and I see oil.
Old Mar 30, 2006 | 11:05 PM
Jman's Avatar
Jman is an unknown quantity at this point
ORIGINAL: kaindragoon36
ORIGINAL: Jman
Jman,
I don't know what to tell ya man. It worked for me.
Old Mar 30, 2006 | 11:08 PM
Jman's Avatar
ORIGINAL: bigbrett
Can't do that with 4x4 unless you remove the driveshaft. Would make for a cheap easy fix if you didn't want 4x4.
Old Mar 30, 2006 | 11:13 PM
Jman's Avatar
ORIGINAL: bigbrett
It won't hurt it to remove the oil cooler. Its relocated for clearance reasons. If you think about it, its only a 4.3. All kinds of motors v8 included never came with an oil cooler and had no problems. Sure the cooler helps but I don't think its necessary. just my opinion
kmartin
13
Dec 27, 2014 10:30 AM
exalteduser
13
Oct 5, 2013 10:12 PM
spatula6554
Apr 10, 2012 02:17 PM
dj00140
Apr 13, 2011 10:48 PM
subarugt06
Mar 6, 2011 11:21 AM
