Running rough and cuts out at higher speed
#91
A leak into the lifter valley will not cause too much of a problem. Oil leak perhaps, but shouldn't cause any driveability concerns. I wouldn't leave it like that though...
#92
my friends is having same problem and they have replaced alot of sensor we are going to drop cat tommorow and see what happens. but the weird thing is that the veh. only had one code egr pintle somthing. no misfire codes or misfires but it has lack of power timing is crazy like yours so let me know if that fixes it i will try to do a coolant leak test tommorrow and see if i see anything leaking. oh yea did you ever have a bklack smoke cloud on start up. this one does it sometimes.
#93
Okay guys. I need help. Where do I find a torque wrench with inch lbs? I have called three local autoparts stores and they say they only have FT/lbs. This is kinda aggravating.
#94
Is there a way to just use a torque wrench that has ft lbs?
#95
#96
I bought one at Lowes that has ft lbs on it.
#97
I've been reading this thread because it describes a similar problem I am having with a lifted 98 2dr ls that I bought a few weeks ago. It was running like crap under load, after about 20 mph it would just bog down and not move, but idling fine and revving in park no problem. Replaced the cat and it runs a lot better except for skipping and hesitation at low speed just before shifting, on the highway it's fine except for slight rpm increase\decrease, about 200-300 rpm. The people that had before me replaced the maf, tps, spider, coil, icm, plugs and wires, cap and rotor, etc... I put a cat and muffler on, magnaflow directfit. So i'm waiting to hear what your outcome is before I go any further.
#98
#99
#100
I meant I bought a torque wrench at Lowes with both ft and inch lbs on it, sorry.
