running weird and threw all these codes at once
well i came back for a work trip being gone for a week i get in start my blazer and it felt sluggish then started cuting out check engine light came on and threw all these
p0122
p0405
p0452
p0404
i looked them all up but any reason why they all came on at once
p0122
p0405
p0452
p0404
Guest
Posts: n/a
Try tapping the part of the egr that is attached with two bolts to motor with socket extension and hammer/remove egr and clean. Replace gasket with screened up-grade. Use di-electric grease on five pin connector. Sticky egr. Chunck O' carbon got tossed.
All of those codes are electrical issues. I don't think the fuel filter will change anything. Double check all of the wiring, and the wires from the pcm.
Have you tried to unhook the battery for awhile to reset everything? It sounds like electrical gremlins to me.
Starving? Have you checked fuel pressure and leakdown?
![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
