rust around filler neck
Old Apr 4, 2007 | 07:42 PM
snowman's Avatar
snowman is an unknown quantity at this point
Default rust around filler neck
just wondering if any body has a solution to surface rust just below top of filler neck.
Old Apr 4, 2007 | 07:48 PM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
Default RE: rust around filler neck
grind it down with a rust removing pad and paint over it with rust proof paint. you shouldint have to take very much material off at all if you do then the strength of the part will be compromized. if it looks like it goes deep into the metal or you can see it on the otherside, you will probably have to get it replaced at a shop.
Old Apr 4, 2007 | 07:56 PM
snowman's Avatar
thanx I was just thinking of putting some rust stop on it, but maybe painting would be better
Old Apr 5, 2007 | 05:40 AM
20Blazer00's Avatar
ORIGINAL: snowman
Unless you got a special radiator the side tanks on the second generation Blazers are plastic. So if it looks rusty it is just Dexcool orange impregnated into the plastic filler neck...
Old Apr 5, 2007 | 05:52 AM
Zygoat's Avatar
wow i thought we were talking about the gas filler neck, whcih one is it the gas or the radiator?
Old Apr 5, 2007 | 10:38 AM
snowman's Avatar
gas filler neck, right below cap flange. thanx.
Old Apr 5, 2007 | 05:27 PM
Zygoat's Avatar
it might be a little rought to get to so make sure you take the time to get ALL of the rust off and it will last a long time.
Old Apr 5, 2007 | 07:37 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
Dexicool itself isnt the problem itself. If you have been putting regular water in there then thats were you get it from. Dump the dexicool and put just regular in there and from now on just put distilled water it there.
Old Apr 5, 2007 | 09:12 PM
Zygoat's Avatar
its the GAS filler neck not the coolent.
antman94
Jan 22, 2011 06:44 PM
aheld
Dec 31, 2010 02:32 PM
CNYCountryKidd
Nov 21, 2009 10:20 AM
Colby 04
Lifting Tech
Jul 3, 2009 06:01 PM
orange drop
Dec 7, 2007 07:25 AM
