RW defog malfunction
Old Oct 21, 2007 | 08:22 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RW defog malfunction
I used my rear window defrost for the first time this year to dry thefog off the insideon my back glass. I turned it on and had it running for about 10 minutes on the way to school and thefog never cleared off.
I determined later that it wasn't working properlywith a DMM. Checked the fuse. Its all good. Seems that the switch isn't working right. The light on the switch comes on, but the strips never warm up. Any ideas guys. Switch or wiring?
Old Oct 21, 2007 | 08:33 PM
Default RE: RW defog malfunction
Here's the diagnostic flow charts for this problem:
As you can see, there are two fuses that can affect this. If you find that you need further information when going down through the list, just let me know.
Old Oct 21, 2007 | 09:46 PM
cliro's Avatar
cliro is an unknown quantity at this point
if your defrost lines are broken, it won't work, so make sure you check those. Sometimes they get scratched off. I've owned a couple vehicles with non operating defrost, and thats what the problem was in them, not fuses.
Old Oct 21, 2007 | 09:51 PM
You would need to have a break in all of the lines for the whole grid to be knocked out.
Old Oct 21, 2007 | 09:54 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
my rear defrost has never worked...but then again..some how the wire doesn't connect to the rear window....guess they didn't need it in florida....might be something else to check...
Old Oct 21, 2007 | 09:56 PM
Well there ya go Karin! If the wire isn't connected it definitely won't work!! LOL
Old Oct 21, 2007 | 09:57 PM
cliro's Avatar
that depends if the scratch is in the grid lines or the primary line that leads to the grid, no.
Old Oct 22, 2007 | 04:51 PM
EuroGoldLS's Avatar
Well Kyle, you pinned it with the flow chart. No power supply to the RR DEFOG fuse. The wire pulled out of the fuseblocksomehow and there was no power at the fuse.
Old Oct 22, 2007 | 09:32 PM
So you got it fixed?
Old Oct 22, 2007 | 09:50 PM
EuroGoldLS's Avatar
Yes sir I did. Pulled out the fuse block and reconnected the wire. That pretty much explains why I couldn't find what was wrong to begin with.
